what to look for when buying a zook
an area for the zook guys to share their tech!
Postby Taziiy » Fri Aug 20, 2010 9:44 pm
Can you people who have owned or own a zook let me know what to look out for when buying a zook good points and bad points as my son wants me to look for one
Taziiy
Postby zook37 » Sat Aug 21, 2010 4:40 pm
What price range, year model and make are you looking at mate?
I can give you the heads up on Grand vitara's (98 to 2004) but thats about it. :cool:
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
zook37
Postby zook37 » Sat Aug 21, 2010 4:42 pm
I can also give you some links to some great zook sites full of info if you like. Just let me know. :angel:
zook37
Postby Taziiy » Sat Aug 21, 2010 8:35 pm
my son is looking at the suzuki sierra looking at around the 90's price he has about 3k so far. Im just looking for things that are common on them like oil leaks where to look rust there common spots things like that
Taziiy
Postby The shadow » Mon Aug 23, 2010 6:49 pm
Rust around the fuel filler cover in the back,if they have been used for wave running, they will rust there.Also around the holes in the floor, if they still have the rubbers in them.Where the body bolts to the chassis,also where the flairs bolt on.the lip where the rear door/gate shut if its a soft top, window frame and where it sits on the car
if i can remember anymore i will post them up
[SIZE="4"][color="Blue"]Dream as if you'll live forever, live like you'll die today.
Powered by Pals, Motivated by Mates.[/color][/SIZE]
The shadow
Location: wallsend or with my Escort. Prolific G string wearer.
Postby The shadow » Mon Aug 23, 2010 6:54 pm
Under the battery
The shadow
Postby Taziiy » Mon Aug 23, 2010 7:07 pm
Thanks that will give me a starting points
Taziiy
Postby red92gq » Tue Aug 24, 2010 10:40 pm
Bent front diff housing .
They dont like being jumped, even in sand dunes.
Also not very happy other halfs when they find out what you've been doing in their cars.
red92gq
Postby slydar » Mon Jun 27, 2011 4:21 pm
step-son in bellingen has in recent years built up a 'fleet' of these little gems (thats what he thinks of them anyway) - easy to work on; his last acquisition he paid $2600 for had been 'bodgied' up a lot behind the scenes with silastic and lots of holes drilled and screws put into sheet metal to keep the rear detatchable canopy on tighter (bringing on a degree of rust) - aside from that he only had to replace all the rubber bushes on the leaf spring mounts and seals on the gearbox and transfer case. most of this he was able to do himself, barr the bushes which required an extra hand to push on the chassis at the right time to line things up
slydar
Return to Zook Tech
Users browsing this forum: No registered users and 0 guests
