Are my 33s doin damage??
For all your general tech help
Postby Cyscoop » Wed Jun 08, 2011 12:32 pm
Hi guys, I've got a set of 33x12.5 tyres on 15x8 cruiser rims slipped under the guards of my 92 hilux sr5. Magical upgrade over the pizza slicers I had on b4 howeva iv noticed that since fitting them wen I'm in 4wd (low n high) I'm gettin a knocking sound thru the front end, faster I drive faster the knock is. I'm assuming that my cvs are probs shot as the whole car is still carrying standard everything since the factory.
Is that noise the cvs and has the increased track width of the tyres caused this problem by putting more load on the cvs n bearings?
Cheers
James
Cyscoop
Postby beaujest4 » Wed Jun 08, 2011 1:38 pm
there is a fair chance the 33s will scrap on the back of the wheel arch, guard and slowly start to scrub things apart
Cheers Al
Life is the Greatest gift we are given, Make it the Greatest thing you do.
https://www.youtube.com/watch?v=_PpzveeXLO8
beaujest4
Postby Cyscoop » Wed Jun 08, 2011 4:08 pm
I've got nearly 3 inches clearance all round the rear end and can put it into full lock with out the front scraping so I'm not phased about the tyres rubbing. It's juz the extra load I may b puttin on the front end bearings n cvs that worries me a lil.
Cyscoop
Postby beaujest4 » Wed Jun 08, 2011 4:19 pm
Under full lock is one thing but try it under full suspension compression or full upward travel of the wheel, then try your full lock
Cheers Al
beaujest4
Postby Cyscoop » Wed Jun 08, 2011 5:15 pm
I go drivin in the Pine Forrest and through the sand dunes at lano and it may nick the edges every now n then but it's 2 b expected from a stock suspension setup...
But thats not wot my initial query was about, cheers 4 the concern tho...
Cyscoop
Postby beaujest4 » Wed Jun 08, 2011 6:24 pm
No worries mate. Noise you are concerned about is it on both sides or just one. Next time your have the room go full lock one way and then the other see which side is making the noise.
Cheers Al
beaujest4
Postby Cyscoop » Wed Jun 08, 2011 9:37 pm
I can hear it on the right side wen turning both left and right wen i poke my head out the window but I can't hear the left side Ova the ambient noise.
Cyscoop
Postby dudelux » Thu Jun 09, 2011 9:16 pm
Sounds just like a noise I had in my Lux, but i was running 31s at the time. I thought it was my CVs, or something busted in my front diff. It turned out to be the double cardan joint in the front shaft was shagged.
Climb under and check all uni joints for excess play, or movement.
I might be wrong, thats happened before, but if Im right, then a front shaft is alot easier to change than CVs are.
LN65 dual cab lux, 2in BL, 35in muds, 33in TSLs, homemade and diy bits and a protective layer of crud
dudelux
Postby Cyscoop » Thu Jun 09, 2011 10:17 pm
I'll jump under on the weekend an hav a proper look, cheers.
Cyscoop
Postby Taziiy » Sat Jun 11, 2011 1:07 pm
is it the wheel scrapping on the calliper
Taziiy
Postby Cyscoop » Sat Jun 11, 2011 2:13 pm
no i had a look this mornin an that seems fine. my cv boots r full of shit n all ripped up tho, got a fair bit of play there 2.
An remember, theres always a way... Over it, Under it, Around it or... Thru it!
Cyscoop
Return to General Technical Help
Users browsing this forum: No registered users and 0 guests
