Top Mount 'cooler for 4JB1T?
Postby Leedo » Mon Nov 10, 2008 3:15 pm
Does anybody know where i can get a top mount intercooler to suit my 96 'Deo.
also is there an aftermarket core that would do the job or maybe a 'cooler off a pajero or something.
anyone that has done this and can give me any info would be great.
Leedo.
Leedo
Postby nig » Mon Nov 10, 2008 5:06 pm
Have not done one myself, but you should find some info to point you in the right direction here:
http://clubisuzu.proboards29.com/index.cgi?board=Enginemods&action=display&thread=1172
Or as an alternative you could look at one of these - dosnt need you to poke holes in your bonnet:
http://www.dencodiesel.com/coolers.html
Postby Leedo » Tue Nov 11, 2008 6:38 pm
thanks mate,
both look like they would do the job nicely. i'm happy with the deo's power but i figured some cooler air wouldnt hurt. i think this one will go into the long term mods list as rego is coming up and i need tyres real bad.
Leedo
Leedo
Postby Leedo » Sat Nov 29, 2008 6:22 pm
do you know of any intercooler off another car that would fit, had a quick measure and it seems like something with maybe a 300mm wide core(maybe 450mm wide all up with endtanks) would fit in the space. i thought maybe the cooler off a later model 3.0 Deo would work but ive never actually seen under the hood of one.
Leedo
Leedo
Postby The Vulcaniser » Mon Dec 01, 2008 8:07 pm
i had a front mount on mine with a 10" fan on it that i turned on in low range to keep air moving through it. It wasn't too hard to plumb up, and worked well. If you search through this forum, there may be some info here..... i have pictures on my computer somewhere.
<IMG src="http://i283.photobucket.com/albums/kk319/Christo1960/i99549739_4478_2.gif" align="middle"</IMG> Ulysses Club - Grow Old Disgracefully <img src="http://downunder4x4.net/ulyssesclub.gif" align="middle"></img>
Reviled did i live as evil i did deliveR
The Vulcaniser
Postby The Vulcaniser » Mon Dec 01, 2008 8:08 pm
i think from memory mine was off a RX-7 turbo...... i have one here that you might be able to hook up top mount. You are welcome to have it if it suits your needs.
The Vulcaniser
Postby KRUZIN » Mon Dec 01, 2008 10:46 pm
mine was a complete import motor with the intercooler fitted. a mate of mine found one locally off a MU i think, look around they are out there to be found..
[font="Arial Black"][SIZE="3"]THEY CALL IT [size="4"]PMS [/size]BECAUSE [size="4"]MAD COW DISEASE [/size] WAS ALLREADY TAKEN..:angel: [/SIZE][/font]
KRUZIN
Postby Leedo » Tue Dec 09, 2008 7:54 pm
Green with envy.
i called handfull of local (newcastle) wreckers and importers.. no one could(or didnt wanna) help. Hytech at cardiff said he does get 4JB1T's in but has not seen a factory top mount cooler, he also went to say i should just go an eBay frontmount job..which is neat if you have a VL Turbo but a bit out there for my Turbo Diesel slug pumping piss all boost..i think.
Leedo
Leedo
