rust what paint?
For all your general tech help
rust what paint?
Postby jcs_1987 » Fri Mar 18, 2011 10:03 pm
hi all... found i far bit of rust on my chassie i have wire wheeled it off but thats the best tp paint over it?
jcs_1987
Postby Taziiy » Sun Mar 20, 2011 5:59 am
use some kill rust then paint some chssis black over it again
Postby red92gq » Mon Mar 21, 2011 9:11 pm
either try an get POR15 complete rust treatment, Very good but pricey.
Or use Norglass marine paint ,both are heaps better than normal killrust
92 TD42 GQ coil cab
90 TB42 Maverick wagon:
red92gq
Postby jcs_1987 » Mon Mar 21, 2011 9:41 pm
where can i get that stuff from?
jcs_1987
Postby 98lux » Fri Mar 25, 2011 8:51 am
jcs_1987 wrote:where can i get that stuff from?
Great stuff.
http://www.ppcco.com.au/prevention.htm
Why Wreck a good thing
Prado 120Series (stock)
HZJ105R Dualcab under construction
98lux
Postby GQuick » Fri Mar 25, 2011 3:51 pm
go the norglass any day of the week ..or for a cheaper option, you could look at fish oiling then a good quality epoxy enamel
Six bent smog billowing screaming pipes heralding the end of the world ...
GQuick
Postby red92gq » Fri Mar 25, 2011 9:20 pm
If you use norglass make sure you rough it up if if you want to paint over it as the other paints wont always stick to it otherwise
92 TD42 GQ coil cab
red92gq
Postby doka » Sun Apr 28, 2013 7:56 am
Krylon Anti-Rust is another good one. Used it quite a bit and works a treat.
doka
Postby slydar » Mon Apr 29, 2013 1:24 pm
got put onto penetrol, available at bunnings - havent been using it long though so cant really compare it to anything
slydar
Return to General Technical Help
Users browsing this forum: No registered users and 4 guests
